69 Users Online (68 Members):
Forums >> Revit Building >> Technical Support >> Detail References
![5 Stars: 2 Votes](/images/stars_5.gif) |
I'm having trouble with my ceiling details. I have several spots throughout the building with the same ceiling detail, and I've made a section: detail view from one location. I'd like to put tags on the other locations, referencing the same drawing/sheet number (the bubble with 1 / A1.1 in it), and have the tags say SIM. beside them. I've looked in the help file, and it seems like this should be possible, but I cannot figure out how... I don't want to have to put eight of the same detail on a sheet just to have it properly referenced on the ceiling plan. Has anyone managed this?
Thanks for your help.
-Erin
28 Posts No Rating |
If I read what you want to do correctly, what you need to do is create a new callout, and check the box that says reference other view (should be on the bar right above the drawing window) then select the view you want to reference. I hope that helps.
Yes, that's what I understood from the help file, but I've got no box to check on the option bar. Is there any other way of indicating that I want to reference another view?
Thanks,
Erin
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
as soo as you pick up the callout tool an option to refer to other views will appear on top.
ooooh... Thanks very much. I kept looking for it after creating another view. I guess that makes more sense anyway... Thanks again.
-Erin
Detail References |
Mon, Sep 24, 2012 at 8:26:51 AM
Intelligent Drawing Detail References in Sentence/Text Format |
Thu, Oct 4, 2012 at 3:47:13 PM
Detail callout head size variable? |
Wed, Mar 6, 2019 at 4:26:35 PM
INDEX OF DETAIL REFERENCES |
Tue, Apr 8, 2014 at 11:41:26 AM
Overlapped Detail References |
Wed, Nov 20, 2019 at 3:18:57 PM
Members: | 2016934 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
