65 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> TRAY CEILING
i am a student trying to learn revit on my own. i am doing a rather upscale house and i am trying to figure out how to put tray ceilings in a few of the rooms can someone please tell me how to do it, or point me in the right direction atleast because i am stuck on this one.
![coreed Avatar](user_avatar/14568.jpg)
one thing that i do is define a roof system that's the thickness of your drywall and use the various roof tools. i'm sure that there are other ways, but i am new too and have been experimenting with this method.
HTH
Go to the modelling tab and use the Ceiling command. Up at the top click the Sketch command and put in the ceiling that is flat around the out side. If the sides of the tray ceiling are sloped start the ceiling command again and Sketch again and then put a slope to the ceiling and then enter again and put the high part of the ceiling in. If the sides are not sloped use a wall style for the sides of the tray ceiling.
![3 Stars: 2 Votes](/images/stars_3.gif) |
Attemping my first tray ceiling. I am trying to use the ceiling method but the problem I am having is it will only let me set one slope. So do I need to piece the 4 slopes? Is it not possible to make the 4 sloped sides as 1 ceiling? USING VERSION 9.1
Edited on: Tue, Aug 14, 2007 at 3:45:19 PM
Cable Tray Clearance |
Mon, Mar 24, 2014 at 10:44:48 AM
Cable Tray- Revit MEP 2013 |
Fri, Oct 5, 2012 at 8:29:45 AM
Cable tray tee |
Tue, Nov 1, 2016 at 7:29:06 AM
Revit 2015 - Ladder Cable Tray |
Mon, Feb 29, 2016 at 5:05:14 PM
Tray Ceilings |
Mon, Mar 10, 2008 at 1:42:35 PM
Members: | 2022290 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
