Forums >> Revit Building >> Technical Support >> MOVING FAMILY INSIDE AN OTHER FAMILY
Wed, Apr 19, 2006 at 6:41:04 AM | MOVING FAMILY INSIDE AN OTHER FAMILY
robert
G'day, i have inserted a family inside a family. i am not able to move it into position. i can rotate it and move it along the horizontal axis but not along the vertical axis. after rotating it 90 degrees it can move along the vertical axis. if the object is rotated it will move along an axis perpendicular to the family to be moved. the costrains box is unchecked and disjoined is checked any ideas? it is driving me crazy. thanks robert. melbourne.
Moving Family Symbols without moving the family in one instance
Sat, Oct 12, 2013 at 1:01:06 AM
Editable nested family inside parametric array host family
Wed, May 19, 2021 at 8:05:22 AM
Annotations nested inside a wall hosted equip family: Cant see the annotation
Wed, Aug 20, 2008 at 6:37:31 PM
line based family inside face baced family
Mon, Aug 6, 2012 at 9:15:42 PM
mass inside family
Fri, Mar 28, 2014 at 8:55:07 AM
Page generation time: 1.0423
