44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Using standardized detail sheets
I've got several small projects that are very similar and I'd like to use the same sheets of details in each of them. The details I am using are old AutoCAD details I've imported into drafting views. I'd like to not have to copy all the linework out of each drafting view into a new drafting view in the next project. Is there a way to copy sheets from one project to another and have the views carry over? If that doesn't work, can I somehow copy all the drafting views from one project to another? Doing it the long way on all of these might just kill me!
![5 Stars: 2 Votes](/images/stars_5.gif) |
Revit Building 9
Make a Template and put them in once then every time that you need those details open the templete and their they are. Another way that I have found that works is import them in to revit then export them back to the same file. Next time you pull them in from that file they will have all the changes made to them. The easiet way is probably the template.
![4 Stars: 2 Votes](/images/stars_4.gif) |
Revit 9 will allow you to establish a detail library to reuse what ever details you need
Typical Detail sheets on my first revit project |
Mon, Feb 8, 2010 at 9:22:07 AM
Can I have one detail on 2 sheets? |
Tue, Feb 15, 2011 at 10:12:11 AM
guide grids on sheets revit 2013 |
Mon, Aug 26, 2013 at 4:11:38 PM
My Section Detail and Numbers will not display on sheets. Can anyone tell me why |
Fri, May 21, 2010 at 5:09:18 PM
Dummy Callout for 2017 |
Thu, Oct 4, 2018 at 8:48:19 AM
Members: | 2022340 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
