46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> gates
12 Posts No Rating |
Has anyone made gates in railings? Is there an easier way than using a general model and drawing the railings around it?
admin
I guess you could make the gate as a separate railing type...depending on how the gate is shaped...
Hiroshi Jacobs
The Catholic University of America |
But then I couldn't show a the swing of the gate...
We've typicall shown the gate in a section of wall to the exact size of the gate. If the gate is 1400mm high and 820 wide make your wall this size to match and place the gate in the wall. You will have to have atleast 1mm or (1/32" depending on where your from) of wall showing either at the bottom or sides so revit doesn't get confused.
Cheers,
Chris Price.
admin
so you would make the gate as a door? I think that makes a lot of sense.
Hiroshi Jacobs
You got it.
Thanks, Chris!
fence gates |
Fri, Aug 3, 2007 at 11:18:48 AM
Adding gates in Revit?? |
Wed, Oct 8, 2008 at 3:44:36 PM
What are ya'll plans? |
Fri, Nov 12, 2010 at 11:26:51 PM
Process Wquipment |
Fri, Aug 30, 2013 at 2:24:48 PM
Circular Tag Links Possible? |
Mon, Oct 22, 2012 at 4:05:36 PM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
