Forums >> Revit Building >> Technical Support >> Curtain wall: Change the glass colour?
4 Posts No Rating |
Hi,
I know this sounds like a newbie question(because I am one), but how do I change the glass in a curtain wall? I know how to change the material of a regular wall, but I tried clicking the "paint" button then selecting the curtain wall and I can't select it. I want to change the glass to the dark red tinted glass in "materials". There must be a way, can somebody help me out?
1. you have to use the tab key and tab until you get the system panel selected
2. click properties button in the option bar
3. click edit/new
4. under Materials and Finishes click on the field for Glass
5. click the down-arrow to the right of it
6. on the Left side select Glazing: Curtain Wall Glazing
7. On the Right side under Shading if there is a check in the Update when AccuRender selection occurs
and you set a color under the color option, it will change the color of the glass in your curtain wall
there may be another method but at the monment i am not aware of it. i am a newbie too.
Post edited on 2006-04-16 19:18:08
Post edited on 2006-04-16 19:18:24
Post edited on 2006-04-16 19:23:15
38 Posts No Rating |
I figured out how to change the color of the 'glass' for the whole project, but is there a way to change each section of curtain wall to its own color? We are looking for a 'MUSAC' type look, and need consective panels to be different colors. any suggestions?
Just make different materials and then apply those materials to the different panel types?
You need to create/duplicate the "Glazed" in several different panels with different colours/materials, then you can assign each panel in your curtain wall to the respective Glazed you want... make sense to you?
I know how to create the different colors of glazing as materials but I dont see where I can change it for each particular section of curtain wall.
Got it! Just had to tab through the system to select only the glass! Thanks again guys!
Alison, why didn't you read what Coreed said: "1. you have to use the tab key and tab until you get the system panel selected ..."
how to change one 1 curtain wall material |
Fri, Sep 5, 2014 at 4:06:44 PM
How to change glass wall to a frosted design? |
Wed, Dec 15, 2010 at 5:52:33 PM
Curtain Wall - Glass and Mullion Detail |
Tue, Oct 2, 2007 at 4:19:30 PM
Graphic Override and Curtain Walls |
Tue, Mar 3, 2009 at 7:26:02 AM
11
Curtain Wall Window Material |
Wed, Dec 15, 2021 at 2:04:35 PM
Members: | 2016873 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
