157 Users Online (154 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Adding Text Below Dimensions
Fri, Apr 14, 2006 at 4:02:58 PM | Adding Text Below Dimensions
justinmthomas2003
How do I add a Text below a Dimension? When I add Dimensions to the plan and I want to add a Text below some of the dimensions like I can with AutoCAD by using Text Override in Properties. Do anyone know how to do it? Thanks
Fri, Apr 14, 2006 at 5:39:30 PM | RE: Adding Text Below Dimensions
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Currently you can only add text after or before (suffix/prefix) in a dimension. To add text below the line you would need to insert it as normal text.
Fri, Apr 14, 2006 at 6:50:36 PM | RE: Adding Text Below Dimensions
gdoorn
1 Stars: 1 Votes
i have also 'forced' certain dimensions by creating an opaque text type, and typing overtop of the displayed dimension (for window schedules where i dont want to show the true finish floor line)
Thu, Jan 11, 2007 at 4:30:03 AM | Adding Text Below Dimensions
beyondthewall
4 Stars: 3 Votes
the problem with putting in 'forced' dimension i.e. opaque text to hide the original revit dimension is that when u export it to autocad, the text loses its opacity and shows the revit dimension below.
Thu, Jan 11, 2007 at 6:00:39 AM | Adding Text Below Dimensions
latemore
latemore Avatar
3 Stars: 2 Votes
this type of question arises so often on this forum, and mr spot has to keep telling everyone that revit dimensions are exact and your model should do the same.
i have a suggestion for the autocad users who need to 'force' dimensions and also create text only notes.  (i am ex autocad btw).  make a very simple 'group' of lines and text, copy as needed, adjust as needed, and you have a non dimension note.  mr spot gave us all the clue some time ago - 'build' the building with revit building, do not cheat, and write text to your heart's content!
Thu, Jan 11, 2007 at 4:24:11 PM | Adding Text Below Dimensions
Westview
2.5 Stars: 2 Votes
I have not found placing an overriding text over the dimension to be a huge problem. I simply move the dimension to the center of the extention line with the grips and type a simple text and place it over the dimension, this masks the dimension and only displays the text when printing.
Thu, Jan 11, 2007 at 5:12:28 PM | Adding Text Below Dimensions
derxaj
3.5 Stars: 3 Votes
Good idea gdroon with the opaque text...what ive been doing is using a dimesion style with a very small text size, like 1/64" or something like that, so its always small enough to be covered by a text box...I like the idea of opaque text though so its all white and you cant see it...
Fri, Jan 19, 2007 at 1:19:15 PM | Adding Text Below Dimensions
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
I can build my Revit building EXACTLY correct and precise with no cheating/fudging and STILL have the need for this feature. You don't have to be in architecture too long before you need a door frame elevation that "VARIES" (by schedule) or a low/no-slope roof detail in which the iso-board thickness "VARIES" (by point on slope). This is similar to how Revit has deemed the "EQ." acceptable. I'm not "forcing" a dimension, I need Revit to allow me to draw it accurately. To flippantly belittle those looking for this ability as cheaters just makes yourself look bad.
Fri, Jan 19, 2007 at 1:39:36 PM | Adding Text Below Dimensions
Westview
2.5 Stars: 2 Votes
I totally agree with the last comment. I often do millwork shop drawings and the shop drawings are done using the Architectural drawings. The building is rairly built exactly as shown. I put a text on the overall dim. verify or site dim. required, this lets everyone know the room has not been field measured, when that is done I replace the text with a dimension and adjust the millwork to suit. If there is not a fixed dimension it lets everyone know the casework can not be produced. Having a text option would be a big help and I would not consider this cheating.
Fri, Jan 19, 2007 at 7:25:00 PM | Adding Text Below Dimensions
latemore
latemore Avatar
3 Stars: 2 Votes
to those users concerned about some of us mentioning 'cheating'.
just clarifying - people like myself respond to revit's inherent accuracy of modelling by being accurate with everything, so that dimensioning reflects that.  where i need to describe rather than dimension, i use detail lines.  a user does not need to be completely accurate if that user sees no need for it.  because revit 'builds' buildings, rather than purely represent them, i have learnt to use such wonderful technology to be even better at documenting.
whatever suits you!
Fri, Mar 2, 2007 at 12:01:53 PM | Adding Text Below Dimensions
#11
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
"HEY! Why are you using a bridge to play your guitar?!"
"Well, it's because of the chords in this song."
"I can play those chords without the bridge. You're cheating!"
"No, see...I can play them without it too, but there is no need for the full fret in every song, this makes a cleaner sound and isn't as tiring during long playing sessions. I mean, I can do it if I had to..."
"Well, you should make the same sound for just as long no matter what. It's how the guitar's made. But hey, if you're not as good at playing it as me that's fine. "
Sat, Mar 3, 2007 at 10:55:05 AM | Adding Text Below Dimensions
#12
robinballew
robinballew Avatar
3 Stars: 4 Votes
WOW this is out of hand... I think the big issue is that the old method of documenting is going out the window. When you feel the need to "cheat" or "fudge" or "use a bridge" in Revit think about what you are doing. Why are you doing it. What are you trying to tell the person using the created document. I don't think it is a questions of right and wrong but a questions of how to convey the information in the most appropriate way. Creating a dimension that makes the viewer of the drawing think the dimension is accurate is cheating. If you need to have a fudge factor then add a note +/- or just add a note to verify in field. It's the same as the guitar analogy. If I can use the bridge the whole song then use the bridge. If I have to remove the bridge half way through use cords. No one is going to jump back and forth using a bridge and not in the same song. Don't jump back a forth using dimensions to reflect inaccurate information when the point of a dimension is to display the distance between two items. THINK ABOUT IT.
BallewDesigns.com
Problems with adding text to dimension lines.
Fri, May 29, 2009 at 8:48:44 AM
Rotating the text in dimensions
Tue, Feb 17, 2009 at 12:18:17 PM
Adding text notes to a detail
Mon, Dec 10, 2007 at 11:55:10 AM
Text width for dimensions...
Tue, Aug 7, 2007 at 7:55:43 AM
TEXT AND DIMENSIONS
Tue, Sep 28, 2004 at 12:49:39 AM
Page generation time: 0.4839
