61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Revit 2015 Disallow join
167 Posts No Rating |
I searched the interweb and I can't find a soultion to this. I found other users who asked the same question but no solution. Right click select opposite wall no disallow join in menu.
Fix Disallow Join Problem
Summary: Create a more precise control for right-clicking the end grip of a highlighted wall so that Disallow Join can be selected without having to swear and throw things.Description: 9 times out of 10 when I try to right click a wall grip end to disallow the join, Revit jumps over to the adjacent wall and selects it instead. Maddening!!Product and Feature: Revit Architecture - WallsSubmitted By: JP Bernier on 11/14/2014
Using Revit Architecture 2012 |
What?
I have had that problem on occasion but it never frustrated me too much. When i couldn't pick it easily, I just isolated that wall then picked it.
It is a little frustrating when you colleagues can right click the wall and the menu with disallow joins pops up and on your system it highlights the opposite wall instead with no disallow join
Poor Petyre. I guess his machine is cursed. Cheers wwhub
I also did what hub says, but finaly found a solution: if you have the TAB key pressed while right-clicking that control point, it works.
0 Posts No Rating |
I do not agree i love it
and found another way: set the plan in wireframe and/or uncheck "select elements by face"
disallow join @ wall creation |
Thu, Mar 10, 2005 at 5:25:11 PM
Disallow wall join of a mid-end face |
Mon, Feb 11, 2008 at 5:54:01 PM
Revit 2014 - Disallow wall joins by default |
Tue, Jun 17, 2014 at 10:23:21 AM
Revit 2015 Ultimate / Standard compatibility? |
Wed, Oct 1, 2014 at 6:10:21 PM
Wall Cleanup |
Thu, Feb 5, 2009 at 2:00:02 PM
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
