65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> hatch pattern not printing
Thu, Sep 29, 2016 at 2:45:20 PM | hatch pattern not printing
Warchitect
4 Stars: 5 Votes
When I make a PDF the hatch pattern just doesnt print.
is it too small? also, when I import the pat file to make the hatch, it breaks when I try to make it larger in the scale factor part of the custom hatch settings. see the picture for info. incl hatch, kind of a rough stone pattern.
how to make it print in a PDF setting is what I need to know.
and no, I dont want to make a general basic hatch, as this is for a client presentation.
Thu, Sep 29, 2016 at 3:29:44 PM | hatch pattern not printing
3.5 Stars: 395 Votes
There is nothing in that pat file to say it's a model hatch.  Is that the pattern that is in the rvt view in your image?  I don't know how it could be if it is a drafting pattern.
What PDF driver are you using?   That could be your problem.
That a pretty large pattern file, that might be why it breaks when scaled.  A similar pattern here at RevitCity works if I remember right:
Thu, Sep 29, 2016 at 3:50:27 PM | hatch pattern not printing
Warchitect
4 Stars: 5 Votes
Cool. yeah I dont know why. but the one you linked works good and also prints with the pattern! thanks!
Fri, Sep 30, 2016 at 11:44:00 AM | hatch pattern not printing
marmiketin1
4.5 Stars: 10 Votes
The issue with the scaling is that revit does not allow values in a pat file to be greater than 1000 or somewhere around there, not sure of exact number. In that file there is a number that is -305.695632 and so if you scale this up to more than 3 times that number will be greater than 1000 and break the pattern.
Fri, Sep 30, 2016 at 1:32:56 PM | hatch pattern not printing
Warchitect
4 Stars: 5 Votes
Ahhhh, great explanation. I looked at the file, lots of high value numbers like that.
Mon, May 8, 2017 at 12:56:51 PM | hatch pattern not printing
DesignPractice
I need some hatch help, just posting to the most recent active thread related to it.
I am trying to create a hatch pattern of Norman brick (11-5/8" x 2-5/8") with grout (3/8") on a half bond.Can't seem to get things to line up. Below is my code. Please help! Any tips?
*Bricks - Grouted Norman Brick;%TYPE=MODEL0, 0, 0, 5.8125, 3, 11.625, -.3750, 0, 2.625, 5.8125, 3, 11.625, -.37590, 0, 0, 3, 5.9375, 2.625, -5.62590, -.375, 0, 3, 5.9375, 2.625, -5.625
Revit not Printing custom made Hatch with Hatchkit
Mon, Dec 22, 2008 at 8:11:17 PM
11
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:35 PM
Hatch pattern
Tue, Jan 13, 2009 at 10:23:47 AM
Hatch 22- Curve Pattern
Wed, May 30, 2018 at 4:07:07 PM
custom hatch pattern without hatch editor
Wed, Jan 28, 2015 at 8:46:58 PM
Page generation time: 0.4876
