50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Dimension Line Weight
Tue, Sep 27, 2016 at 2:27:42 PM | Dimension Line Weight
lpluger21
How do you change the weight of a dimension? I did some research and it says you can chagne it under the line weights flyout and then under annotation line weights, but I am unclear as to what I am chaning. What do the 1-16 corrolate to? Is there no way to change a specific annotation type instead of a global change? Some guidance and clairification wouldbe greatly appreciated.
Wed, Sep 28, 2016 at 12:16:10 AM | Dimension Line Weight
Thread Post Kudo! #2
bitslap
The lineweights 1-16 are essentially identifiers for your preset lineweights.  It allows you to visualise it as a hierarchy of 1-16 increasing thicknesses rather than a bunch of arbitrary numbers.
To change dimension lineweights, draw a dimension, select it, then go to Properties->Edit Type.  There are options to change both 'Line Weight' and 'Tick Mark Line Weight' based on the presets.
To create a new style, click 'Duplicate' up the top of Edit Type dialogue.
FYI a lot of your project work will be duplicating existing types and changing parameters to get your result. e.g. I use floors for gardens and curtain walls for fences.
Thu, Sep 29, 2016 at 12:11:42 PM | Dimension Line Weight
marmiketin1
4.5 Stars: 10 Votes
as bitslap said you can change your dimension lineweight like this.
Fri, Oct 7, 2016 at 1:32:53 PM | Dimension Line Weight
lpluger21
Thank you! I guess I was definitely making things harder than they needed to be.
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:30 PM
Dimension line, line weights won't change
Tue, May 26, 2009 at 6:54:22 PM
Line Weight as Family Parameter
Fri, Mar 16, 2007 at 4:23:59 PM
Making Line Weight a Parameter?
Mon, Mar 19, 2007 at 1:59:56 PM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:54 AM
Page generation time: 0.6420
