47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall to Roof Join Issue
Thu, Sep 15, 2016 at 1:50:26 PM | Wall to Roof Join Issue
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I have a wall assembly that I want to join to a similar roof assembly and Revit is having a hard time doing this correctly. All the priority and core information match to each other but Revit is disobeying. Does anyone have a technique to get Revit to do this right? Thanks.
Thu, Sep 15, 2016 at 2:48:33 PM | Wall to Roof Join Issue
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
As far as I know, roof with wall will not join the same way as walls do. I would cut the edge of the roof with a void sweep at 45 deg angle and use attach tool to extend the wall to the roof.
…or, draw ref plane at 45 deg and attach the wall to it. Then, having the roof aligned with the outer edge of the wall, join them. You might need to switch the join order to get the proper result.
Edited on: Thu, Sep 15, 2016 at 3:11:23 PM
Thu, Sep 15, 2016 at 3:12:23 PM | Wall to Roof Join Issue
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
eeee. I don't like having to create a bunch of other modifying geometry. This will create too many issues when making revisions. I was hoping for a solution that utilizes the priority layering. I've done this successfully in the past with a wall sitting on a floor, but not one where the wall meets a roof. If you know of any other tricks let me know! Thanks!
Thu, Sep 15, 2016 at 3:38:27 PM | Wall to Roof Join Issue
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Lol, it’s just one extra ref plane or a void, but if it’s not working for you, you can try another option (see picture). I couldn’t get it to work perfectly, but it’s close.
I don’t think unlocking the wall layers and playing with their extensions will do any good, but you can try it as well.
Mon, Sep 19, 2016 at 6:17:23 PM | Wall to Roof Join Issue
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Actually, I found that unlocking the layers, and sketching the floor/roof to the appropriate layer in the wall is the best method so far. It maintains the most automatic functionality of the elements without custom void objects. Thanks for your input. In the end I think this is an issue that falls in Autodesk's court since there are not enough options supported for these types of join conditions. Really, these objects simply need to obey the priority layers and it would probably work fine. Oh well. It's not perfect. Cheers.
Roof-Wall-Join-Tricks
Sat, May 22, 2010 at 1:32:24 PM
Roof Joining Issue
Fri, Jan 4, 2013 at 2:37:38 PM
Roof/wall join: Cut roof
Tue, Apr 27, 2010 at 7:53:13 AM
Roof join (s)
Tue, Feb 14, 2012 at 8:11:44 PM
Join roof to multiples roofs
Tue, Jan 16, 2018 at 1:59:08 PM
Page generation time: 2.1667
