Forums >> Revit Building >> Technical Support >> How do I slope a curved roof by extrusion??
I have Revit 2015 and have been trying to slope this curse for a while.. I am sure there is an easy fix to this. Please help!!!
A better description would help.
I have a simple roof extrusion that is curved at 45 deg. and I need one end of the roof at say 10ft and the other at 20ft.
I posted some pics but will prolly take a while to appear.
You didn't post any pics here in your message where they would be useful.
Am I correct that this roof will be an arc in section? As I said, without an image. your description is not clear.
This may help you: http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-A434D87A-A441-4633-9839-BB755310D29F
Yes, it would be an arc in secction.
if you build for walls slap an arc/curved roof extrusion on it, how do I elevate one end of the roof? say 10ft above the other end.
I posted pics in a previous comment, but someone will have to look at them before allowing the post, incase of lude things i am sure..
*four walls
If the work plane option does not do wehat you need, you can also model in place with a blend.
Sloped and curved roof |
Mon, Jan 2, 2012 at 10:07:28 AM
Joining Roof By Extrusion |
Mon, Jan 31, 2011 at 8:15:14 AM
how could I add a slope in my roof by extrusion? Revit2010 [ 1 2 ] |
Thu, Oct 22, 2009 at 11:12:47 AM
19
Revit 2012 Roof by extrusion |
Sat, Nov 19, 2011 at 4:49:20 AM
Barrel tile roof by extrusion |
Fri, Jan 14, 2011 at 1:10:17 PM
Members: | 2119384 | Objects: | 23205 | Forum Posts: | 152301 | Job Listings: | 3 |
