48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2016
Wed, Sep 14, 2016 at 3:29:51 PM | Revit 2016
jmqrsq
5 Stars: 3 Votes
Can someone help me with what I am trying to achieve here? I want my profile to be vertical throught the sweep. Is there a a way to do this?
Thanks
Wed, Sep 14, 2016 at 3:36:11 PM | Revit 2016
jmqrsq
5 Stars: 3 Votes
Wed, Sep 14, 2016 at 8:49:13 PM | Revit 2016
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
How about a railing tool?
Thu, Sep 15, 2016 at 10:34:57 AM | Revit 2016
jmqrsq
5 Stars: 3 Votes
Ya I tried that. Problem is its an ellipse and a helical. When I select the ramp (which is a floor) as the host it stays horizontal and does not follow the ramp. I also exported to sketchup and tried it with the follow me command and it ends up looking the exact same.
Any other ideas?
Thu, Sep 15, 2016 at 11:12:38 AM | Revit 2016
Bartholomew
5 Stars: 2 Votes
It looks like you created your “ramp” with the Floor tool and created a cross-slope using the Modify Sub-Elements tool. In that case, I think your sweep path for the “wall” is following those cross-sloped floor edges – placing your wall perpendicular to those planes. Couldn’t you correct by using Modify Sub Elements again to “level out” a surface onto which to place your “vertical” wall? One other thought: perhaps you could cross-purpose the Slab Edge tool to accomplish what you are trying to do?
Massing appears when exporting from revit 2016 to navisworks 2016
Tue, Feb 2, 2016 at 11:28:30 AM
Revit 2016
Thu, Mar 31, 2016 at 11:00:08 AM
12
REVIT 2016 R2
Thu, Dec 10, 2015 at 5:18:21 AM
Revit 2012 to Revit 2016 - Removing Ghost Surfaces Visualization Effect
Thu, Mar 31, 2016 at 10:00:40 AM
Is it possible to Extrude a 2-D profile as a sweep in a Revit 2016 LT project?
Sat, Dec 12, 2015 at 3:58:54 PM
Page generation time: 3.9659
