101 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Aligned dimensions
Wed, Apr 12, 2006 at 2:48:36 PM | Aligned dimensions
same
Is there a way to dimension between 2 points that are neither horizontal nor vertical to one another. In autocad this is done with the aligned dimension feature, but the aligned feature in Revit seems to insist that you select lines that are parallel, rather than allowing, for example, 2 corners to be chosen.
Wed, Apr 12, 2006 at 3:22:32 PM | RE: Aligned dimensions
TomDorner
4.5 Stars: 25 Votes
You can select the endpoint of a wall or object by hovering over it and "tabbing" until you see the blue square indicating the endpoint of something. Revit 9 out today will let you dimension to non-parallel objects. You can also add your own reference planes as well to get things to dimension the way you want. HTH Tom
Aligned dimensions on non-orthogonal walls
Sun, Jun 11, 2006 at 8:16:12 PM
Aligned dimensions for centering curtain wall door
Fri, Dec 23, 2011 at 6:26:41 AM
aligned acting like linear (up-down, left-right)
Tue, Dec 6, 2011 at 4:00:41 PM
Aligned Dimensions Shift While Moved
Mon, Dec 12, 2011 at 12:43:42 PM
Radial dimensions won't display but linear will?
Thu, Jan 23, 2020 at 2:09:02 PM
Page generation time: 3.0583
