90 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> .pat file - running bond with angled tiles
Thu, Sep 1, 2016 at 6:03:37 PM | .pat file - running bond with angled tiles
sequeirs
Hello, I am trying to take the below lines:
*Id Series Eure Tile 2,  running bond
;%TYPE=MODEL
0,             0,             0,             0,             2
90,            0,             0,             2,             4.875,         2,              -2
and change it so that the "tiles" are actually angled at 60 degrees. When I change the angle to 60 degrees the vertical lines no longer stay within the courses, and after playing with the offsets and the shifts I haven't been able to get them back in. I can get it so that most of the pattern looks okay, but if is applied over a large anough surface you can see that the vertical lines slowly start to creep out of the courses. The tile itself is 2"x9.75", with 60 degree angles. Any help would be great. I am in 2016.
Fri, Sep 2, 2016 at 9:13:50 AM | .pat file - running bond with angled tiles
3.5 Stars: 395 Votes
Is the whole pattern angled?   Hugh?  - Its a model pattern! - Rotate it
Fri, Sep 2, 2016 at 10:50:04 AM | .pat file - running bond with angled tiles
marmiketin1
4.5 Stars: 10 Votes
You can tab select a pattern line and rotate it when using a model pattern, which is what you are using.
Fri, Sep 2, 2016 at 11:02:51 AM | .pat file - running bond with angled tiles
sequeirs
Rotating a model pattern can be very effective in certain situations, but won't work here. Picture a bunch of parallelogram shaped tiles running in a running bond (the tiles themseves having an overall dimension of 2" x 9.75"): that was what I am trying to accomplish. Rotating the existing pattern will keep the tiles rectangular, but just tilt them.  =)
Fri, Sep 2, 2016 at 11:10:28 AM | .pat file - running bond with angled tiles
So you are saying the tiles are parallelograms?  That was not clear in your original post.  The "with 60 degree angles" does not mean that since the tile would have 2 60's and 2 30's.
Something must be wrong with your numbers.  A rounding error probably so look again at your calculation for those...add more places if necessary.
Might be easier to use hatchkit.
Fri, Sep 2, 2016 at 11:39:10 AM | .pat file - running bond with angled tiles
sequeirs
.... PLEASE DON'T HIT REFRESH BECAUSE IT JUST REPOSTS YOUR LAST POST ....
Edited on: Fri, Sep 2, 2016 at 12:05:47 PM
Fri, Sep 2, 2016 at 12:37:00 PM | .pat file - running bond with angled tiles
sequeirs
Unfortunately hatchkit has been giving me a fatal error that causes Revit to shut down completely, so I've been trying to hack this the old fashioned way.
Sat, Sep 3, 2016 at 5:35:19 AM | .pat file - running bond with angled tiles
hugh
3.5 Stars: 4 Votes
These tiles?
http://www.designanddirectsource.com/products/product/id-series-eure
How arranged? This is a running bond:
-;        Written by HatchKit for Revit
;        HatchKit for Revit (c)1990-2016 Cadro Pty Ltd
;        www.hatchkit.com.au/
;-Date                                   : 3/09/2016
;-Time                                   : 8:26:40 PM
;-HatchKit Version                       : 3.1.8.2681
;-HatchKit Output Filetype               : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*EureID
;%TYPE=MODEL
30,0,0,0,2
90.0020471178,0,0,48.5605630203,-0.111104235002,2.3094,-173.201461487
However I am most alarmed by your report that HatchKit can misbehave within Revit.
Please get in touch with an email to support(AT)cadro.com.au for assistance.
hth,
Hugh Adamson
www.cadro.com.au
Hugh Adamson
www.hatchkit.com.au
Thu, Mar 30, 2017 at 4:27:52 PM | .pat file - running bond with angled tiles
lslough
Using this code, how would you add a 1/8" grout line to this pattern?
Thu, Mar 30, 2017 at 6:28:09 PM | .pat file - running bond with angled tiles
hugh
3.5 Stars: 4 Votes
That pattern contains an unbroken line for the horizontal joints.
A grouted tile pattern will contain four sets of broken line repetitions Like this:
;-Date                                   : 2017-03-31
;-Time                                   : 10:24:59 AM
;-HatchKit Version                       : 3.1.9.2674
;-HatchKit SerialNumber                  : RTA7396388002
;%VERSION=3.0
;%UNITS=INCH
*Grouted6inTile,RUNNING HORIZONTAL 6"x6" bond=1/2
;%TYPE=MODEL
90,0,0,6.125,3.0625,6,-6.25
0,0,6,-3.0625,-6.125,6,-0.125
-90,6,6,6.125,3.0625,6,-6.25
180,6,0,3.0625,6.125,6,-0.125
the above was created with the Brick&Tile wizard contained in HatchKit.
hth,
Edited on: Thu, Mar 30, 2017 at 6:29:59 PM
Edited on: Thu, Mar 30, 2017 at 6:30:33 PM
Hugh Adamson
www.hatchkit.com.au
Custom Running Bond Brick Pattern
Fri, Aug 26, 2016 at 2:38:25 PM
Need help with a Staggered/ Running bond pattern with angles
Wed, Jun 23, 2010 at 11:54:57 PM
4’ x 8’ running bond hatch.
Thu, May 8, 2008 at 7:02:50 AM
Split Faced CMU model material pattern help???!?!?!?
Fri, Jun 1, 2007 at 1:20:29 PM
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
Page generation time: 0.9871
