Forums >> Revit Building >> Technical Support >> Schedule curtain panel by level?
![clickster Avatar](user_avatar/417572.jpg)
I have a 42 story tower model. The facade has been modeled using curtain walls, each modelled on a floor by floor basis (42 curtain walls stacked on each other).
I'm trying to create a curtain panel schedule which totals the area of my glazed panels, on a level by level basis.... but when I'm creating the schedule, it doesn't seem like there is a way to tie each panel to the level it appears on (even though each panel sits whithin a curtain wall that has a unique level base constraint)
Anyone know how I could create a schedule which ties levels to curtain panels? Please help!
Fill what is empty. Empty what is full. Scratch what itches. |
![5 Stars: 2 Votes](/images/stars_5.gif) |
it doesnt say "level" but "base constraint"
silana,
FYI, there is no option to add a "base constraint" field in a curtain panel schedule.
u must use wall schedules, there u have that field. curtain walls are walls
I am not trying to schedule the curtain wall, only the panels within the walls. I want to create a schedule that lists all the panels within a curtain wall and gives the total area (for each level)
then use "material takeoff schedule", (two lines below "schedule cuantities" there u have system panel field. And you can add in the comments of curtains the level where they belongs to
Edited on: Fri, Sep 2, 2016 at 3:46:18 PM
Edited on: Fri, Sep 2, 2016 at 3:47:35 PM
Edited on: Fri, Sep 2, 2016 at 3:48:03 PM
ok... but this method requires me to select each panel and add a 'level' comment. I can't understand why the panel would not be tied to the base constraint of the host curtain wall.
Do this: select all the curtains in a floor, then filter the selection checking only panels, add to the instance comments field the level where they are and then make the takeoff schedule.
there's nothing to understand, actually, but programs are not perfect, so you must use them the best way you can.
And no, you dont have to select panel one at a time, you can do it all at once in a 3d front view for instance and add the comment all at once too
ok, yes thank you, I will do that. for your responses
Filtering curtain panel schedule by type |
Mon, Nov 4, 2013 at 9:10:40 AM
curtain panel door not reading completely in schedule |
Thu, Jun 30, 2011 at 1:56:58 PM
CURTAIN PANEL TRICK -- HELP! |
Fri, Nov 30, 2012 at 2:05:27 PM
Curtain system panel problem |
Tue, Jul 10, 2007 at 10:08:07 AM
Multi-Category Material Takeoff - Curtain Wall as Curtain Panel |
Tue, Oct 11, 2016 at 5:53:46 PM
