130 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> DEFUALT side of the level indicator
Thu, Sep 1, 2016 at 7:35:07 AM | DEFUALT side of the level indicator
online2000
online2000 Avatar
is there a way to reset the default side of the level indicator for levels?
this is usually a problem when levels are created by sketching... 1 is from left to right and then the next was righ tto left...
it's really irritating to reset them for each section/elevation view
any ideas??
eli
Thu, Sep 1, 2016 at 8:42:26 AM | DEFUALT side of the level indicator
I looked at this awhile ago and as I remember it, just like for column lines, it is a begin/end feature.   As such, I don't see any way of setting a single end to a left/right when they are not drawn the same way.
Thu, Sep 1, 2016 at 8:54:21 AM | DEFUALT side of the level indicator
I don't have Revit here.... You might try picking the offending level lines and mirooring them (no copy).
Thu, Sep 1, 2016 at 12:03:31 PM | DEFUALT side of the level indicator
marmiketin1
4.5 Stars: 10 Votes
Within the level line system family you can change the bubble default end to either 'symbol at end 1' or 'symbol at end 2' in the type properties. Select a level line and then edit type to see the properties.
Thu, Sep 1, 2016 at 2:01:12 PM | DEFUALT side of the level indicator
marmekintin1,  you must have missed what was written in the original post.   Your answer does not apply here.
How do I get rid of these indicator lines around my slab?
Sun, Nov 28, 2010 at 2:10:35 AM
2019 snap indicator color
Mon, Jun 3, 2019 at 2:54:05 PM
Please Help - How to get Level Tags on same side of all elevations??
Thu, Jan 3, 2013 at 2:14:19 PM
Spot Elevation Bottom Indicator
Mon, Feb 9, 2009 at 2:13:49 PM
Snap Indicator Color
Tue, Oct 8, 2013 at 10:05:02 AM
Page generation time: 1.2063
