72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> Two monitors
Wed, Apr 12, 2006 at 10:50:15 AM | Two monitors
allstate45
allstate45 Avatar
3 Stars: 2 Votes
When rinning Revit on two or more monitors, does revit look like one big screen or can you put different project in each screen? My boss is thinking about getting me four monitors.
Fri, Apr 14, 2006 at 9:19:19 AM | RE: Two monitors
allstate45
allstate45 Avatar
3 Stars: 2 Votes
anyone.
Fri, Apr 14, 2006 at 9:34:52 AM | RE: Two monitors
rkitect
rkitect Avatar
4 Stars: 29 Votes
I don't have any experience with multiple monitors in revit, but I would imagine the revit program would act however you have the monitor output set up. If you have the output set up to make 4 monitors into 1 large screen then it will be 1 big screen (maximized of course) Otherwise so long as your CPU can handle you can open as many instances of revit as you like and put one on each monitor if you'd like. Correct me if i'm wrong. As I said, I have no experience with revit and multi monitors.. just multi monitor outpout in general.
Fri, Apr 14, 2006 at 10:32:18 AM | RE: Two monitors
tito
It looks like one big screen, al you can do is minimize the program window and stretch it across. 4 monitors sounds like overkill ...
Fri, Apr 14, 2006 at 11:08:54 AM | RE: Two monitors
Xane
You can use more monitors, stretch revit to fit all monitors and open many projects you can, arrange windows-views on that 'big' screen manualy. It is very usefull to have open more views of one project, floor plans and 3D ... or section in same time, or more diferent projects or open Revit in one monitor and other monitor is something else, Acad or browser or TV ...
Fri, Apr 14, 2006 at 11:17:05 AM | RE: Two monitors
asdfjkl8
yes you can put different revit "views" on different monitor with the revit program open once. it is really handy having more real estate to work with. Good luck.
Mon, Apr 24, 2006 at 12:03:09 AM | RE: Two monitors
vector23
vector23 Avatar
2 Stars: 16 Votes
i had two monitors for awhile but went back to two.. got tired of turning my head back and forth.. i can alt tab from window to window easier then turning my head.. and more than two would really be no good..
Mon, Apr 24, 2006 at 12:05:16 AM | RE: Two monitors
vector23
vector23 Avatar
2 Stars: 16 Votes
opps i had two monitors for awhile but went back to one.. got tired of turning my head back and forth.. i can alt-tab from window to window easier then turning my head.. and more than two would really be terrible.. if you think you need more screen space just get a 21" monitor and set to 1152 by 864 and put your head back on the head-rest and relax of course everybody has a totally different idea of everything if you know what i mean
Wed, Apr 26, 2006 at 11:08:36 PM | RE: Two monitors
fordd
i'm thinking of getting a 27" what are the pros and cons of one big one or two medium sized ones?
two monitors?
Wed, May 3, 2006 at 7:30:53 PM
Dual Monitors with 2011
Thu, Jul 15, 2010 at 1:44:28 PM
Multiple monitors
Tue, Nov 20, 2007 at 8:53:21 PM
Using 2 monitors
Tue, Jun 14, 2005 at 10:08:29 PM
Dual Monitors
Sat, Feb 23, 2008 at 9:44:44 PM
Page generation time: 0.1897
