36 Users Online (34 Members):
Forums >> General Discussion >> Revit Project Management >> AREAS IS SECTION VIEW...HELP!
Hi Chaps, the issue is the following:
without going through the project that can result boring,
I have a residential project with 60units and 20 section views. On each section view I need to do some filled region in order to calculate some area of the ground excavated. it will became a backfill afterwards. I was thinking to extract the area in section and then moltiply by the lengh of each house.
I would like to: - "schedule" the region areas relating to each section and label them. (I know that region dimensions can't be on a schedule, so I need some alternative...)
1) what can I do instead of using the filled regions in order to schedule the areas in section view?
2) how can I relate the "object" that will give me tha area to the corrisponding section view in a schedule?
Many thanks
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
Have you looked at using a site plan with cut and fill calculations. Start HERE in your HELP.
Section Bubble to Reference Key Plan Grid Areas |
Tue, Jun 29, 2010 at 12:16:32 PM
viewing areas in 3D or isometric view |
Tue, Sep 6, 2011 at 10:06:09 AM
Section box in Section?? |
Sat, Dec 10, 2011 at 10:23:01 PM
13
Wall tile areas |
Mon, May 4, 2009 at 7:19:25 AM
Section line disappears from plan when section view is placed on same sheet |
Thu, Sep 4, 2014 at 7:46:20 AM
Members: | 2025999 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
