63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Send to back/bring to front
Fri, Aug 12, 2016 at 6:57:44 AM | Send to back/bring to front
GLKIRK
In a callout in my 2013, using the earth filled region hatch and concrete columns, I have a hard time making the send to back/bring to front to work the way I would like it to.
I have been able to make it work occasionally, but usually have to back add edit the region boundries.
Could anyone tell me if I m missing something substantial with the manipulation of this feature?
Thanks!
Gary
Fri, Aug 12, 2016 at 7:11:21 AM | Send to back/bring to front
marmiketin1
4.5 Stars: 10 Votes
Detail items will always draw in front of model elements. You need to trace the boundary of your region around the objects that you do not want covered.
Sat, Aug 13, 2016 at 2:20:23 AM | Send to back/bring to front
archigrafix
5 Stars: 4 Votes
You can sort the draw order of detail components in a view. Draw order options are available when you select detail components in the view.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Revit/files/GUID-8369F5F7-35D4-434A-9BF7-4120014F4506-htm.html
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
BRING TO FRONT/SEND TO BACK
Fri, Dec 9, 2011 at 7:58:02 AM
bring to front/send to back?
Fri, Jun 7, 2013 at 7:47:03 AM
Bring To Front
Thu, Mar 5, 2009 at 12:54:54 PM
Title Sheet text sent to back? or transparent?
Wed, Mar 4, 2015 at 3:25:01 PM
BRING TO FRONT COMMAND FOR REVIT?
Tue, Nov 25, 2008 at 10:40:33 AM
Page generation time: 0.5709
