61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> RC Staircase and Levelling Concrete Issue
Fri, Aug 12, 2016 at 3:29:54 AM | RC Staircase and Levelling Concrete Issue
Zone01
Hi everyone, I have a question about the representation of R.C. staircase construction in revit. The way we build RC staircase in real life is (which is a very old fashion method I guess); We first cast the concrete into the formwork along with the slab, then before putting the ceramics on, pour another layer of concrete over it, as thick as the levelling concrete, just to bring the steps to the same level with the floor. The reason for this application is the low quality workmanship. You never know how thick the levelling concrete become at the end of the day. To resolve this uncertainty, they basically fill each step with more concrete. My question is, how can I offset risers, and lift treads up to replicate our construction method in revit?? What I was doing up until now is, basically I set the stair thickness slightly more then detail it in sections. Is there a way to create a parametric family for treads and risers, so i can offset them according to my levelling concrete thickness in the project? Also and a layer of concrete between ceramics and staircase structure? Please check the screeshots to have a better idea.... I would be grateful if someone can help me in this regard! Thanks...
Fri, Aug 12, 2016 at 4:22:01 AM | RC Staircase and Levelling Concrete Issue
archigrafix
5 Stars: 4 Votes
I suspect that is too much variables for the stair families. Either you model in place or do a region in the section (as you did on the left drawing?).
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Fri, Aug 12, 2016 at 7:21:06 AM | RC Staircase and Levelling Concrete Issue
marmiketin1
4.5 Stars: 10 Votes
You could look into using a nosing profile and have a tread depth parameter so that it extends the dept of the stair and add a thickness parameter to control the height. The profile could also include the riser with parameters added to contol those properties
Edited on: Fri, Aug 12, 2016 at 7:23:06 AM
Staircase not going to levels?
Mon, Mar 7, 2016 at 6:06:53 PM
Staircase help - winder staircase
Wed, Nov 28, 2007 at 4:31:49 PM
custom riser height for staircase
Wed, Mar 24, 2010 at 12:08:36 AM
Revit 2014 Crashes When Moving Staircase
Thu, Jan 14, 2016 at 3:26:48 AM
Openings in staircase
Sun, May 26, 2013 at 11:21:11 AM
Page generation time: 0.7658
