11 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> lock wall to grid
Thu, Aug 11, 2016 at 4:37:02 PM | lock wall to grid
SteveB
3.5 Stars: 5 Votes
Using r2015, is there a way to draw a wall aligned to a grid line with the "core face exterior" option selected and having the "lock" function work to click it and lock the newly drawn wal to the grid line.  I am using "chain" wall option un-checked.    I remember doing this in the past.    It seems to only work now if the CL of wal is the drawing option.  And then it only seems to wrok when the wall is being drawn NOT starting from a grid intersection.
Thu, Aug 11, 2016 at 5:09:31 PM | lock wall to grid
archigrafix
5 Stars: 4 Votes
What about locking a dimension from the gridline to the wall line that you want? Does that not work?
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Thu, Aug 11, 2016 at 5:12:58 PM | lock wall to grid
SteveB
3.5 Stars: 5 Votes
Yes, but it is very tedious to zoom in to pick the correct wall face then individually lock every wall to its grid.
Mon, Aug 15, 2016 at 7:23:47 AM | lock wall to grid
marmiketin1
4.5 Stars: 10 Votes
why is it you need to lock your wall to your grid? are you planning on moving the grid and want the wall to move with it?
Mon, Aug 15, 2016 at 7:42:32 AM | lock wall to grid
SteveB
3.5 Stars: 5 Votes
Yes, to allow moving the grid to adjust the design - all walls etc should follow along in alignment.   Or conversely, being certain editing doesn't move the wall from its intended location on the grid.   the idea is to make this easy.  Of course I can go back in and individually lock the walls to the grids, but that's tedious.   Seems like a pretty standard need - locking walls to grids.
I remember (incorrectly?) that I have prevously removed the "chain" check mark and locked the wall as I drew which allowed to lock the walls as they are drawn.  I feel like there is some setting I don't see.
Mon, Aug 15, 2016 at 10:45:32 AM | lock wall to grid
marmiketin1
4.5 Stars: 10 Votes
the only solution i can think of is aligning all walls to eachother that are located on grid line and locking them then if you do move the grid you just have to pick one wall and move it with it and all the walls will move also.
lock to grids
Mon, Jan 16, 2017 at 11:45:53 AM
Any trick to lock the a curtain wall?
Tue, Nov 2, 2010 at 8:30:13 AM
changing grid lines angle - walls are detached
Fri, Apr 20, 2007 at 6:29:43 PM
Curtain Wall Grid Issues
Tue, Dec 23, 2008 at 8:47:00 AM
Curtain Wall Grid Angle
Tue, Feb 15, 2011 at 2:42:32 PM
Page generation time: 0.9784
