29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> text title block from parameters out of a family
Wed, Apr 12, 2006 at 7:20:23 AM | text title block from parameters out of a family
elvis
hi all, 3 questions: 1 is it possible to have a text block where the text is generated from a parameter value: example: parameter values are "height windowframe" and "width windowframe" the textblock should automatically fill in the values of the parameters, even if changed. 2 like above but can this text block be aswell inside the family or outside the family? 3 how to set the visibility so that the generated text is only visible in the "fine detail" mode?
Wed, Apr 12, 2006 at 7:29:02 AM | RE: text title block from parameters out of a family
coreed
coreed Avatar
4 Stars: 16 Votes
here is a mini-clip from DGCAD that shows how to do somthing similar with window and door tags. this may help get you started http://www.dgcad.com/downloads/CADCLIP-WINDOW-AND-DOOR-TAGS.wmv Right Click and "Save Target As.." Post edited on 2006-04-12 07:30:56
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
project title block
Tue, Dec 1, 2009 at 2:18:45 PM
Shared Parameter In Annotations
Tue, May 22, 2018 at 5:44:20 PM
Creating Custom Title Block for the Newbie
Thu, Sep 13, 2012 at 4:48:16 AM
Loading hatches and text styles into title block family
Wed, Jan 4, 2012 at 11:50:49 AM
shared parameters vs lables on a title block
Tue, Feb 8, 2011 at 2:30:45 PM
Page generation time: 1.5075
