85 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Elevation Tag Doesn't Work in Rotated Viewport!
Wed, Aug 10, 2016 at 4:49:54 PM | Elevation Tag Doesn't Work in Rotated Viewport!
ericlovell
Ok, so here's the problem. I have an elevation tag that works totally fine with all the typical ways of drawing things in Revit 2016. One team in my office had to rotate the viewport of his drawings because every single time he would rotate it with the pull down menu, it would then rotate the title and we couldn't figue out how to fix that. BUT! Whenever we put this elevation tag into that project, the text in the elevation tag are in the wrong orientation. They should read normal but this keeps changing to read it as if the right side of the page were the bottom. Does anyone know how to fix this? Please help
Wed, Aug 10, 2016 at 5:57:00 PM | Elevation Tag Doesn't Work in Rotated Viewport!
You are using the wrong rotate.   You are using rotate view on sheet.   With that process the entire view, text title are all rotated.   Instead, open the view with the crop boundry on.   Pick the boundry and rotate it.  The model elements will rotate *this view only)but the text and callouts will remain normal to your screen.
Wed, Aug 10, 2016 at 6:16:18 PM | Elevation Tag Doesn't Work in Rotated Viewport!
ericlovell
Ah! Duh. That fixed it.
viewports & section tags
Fri, Aug 5, 2005 at 7:57:24 PM
Viewport title rotation
Wed, Oct 30, 2013 at 10:20:24 AM
Rotating View Titles
Fri, Feb 6, 2015 at 11:30:25 AM
ELEVATION CALLOUT DOESN'T SHOW UP IN DETAIL VIEW
Mon, Jul 29, 2013 at 4:50:17 PM
Viewport Text
Wed, Mar 9, 2016 at 10:00:08 PM
Page generation time: 13.7720
