43 Users Online (41 Members):
Forums >> Revit Systems >> Technical Support >> How to create surfaces in a new family
Hello everyone!
I'm modelling a new family to create a curtain (textile) with an hanging structure directly fixed on the wall. I started from the preset Metric Generic Model Wall Based, creating the steel element. Now I realized that's not possible to make surfaces with this metric generic model wall based, but only solids.
So, any suggestion about how could I create the gathered textile of my curtain?
Thanks
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
To make surfaces you just need to make your solid geometry thin. All built things (textiles included) have a thickness which you can adjust in the family.
Easy! Ok, I will try this...
Many thanks!
...another little hint, please.
Why it is not possible to offest splines!?!
Ok, ok. I got it! (I was using a too big offset value!)
how to create parametric double curved surfaces!!!! |
Fri, May 21, 2004 at 7:20:48 AM
System Family:Surface |
Thu, Mar 5, 2009 at 1:41:41 PM
Angular surfaces |
Fri, Oct 16, 2009 at 2:23:30 PM
Revit 2010 Extruding Multiple Surfaces all at once? |
Mon, Feb 15, 2010 at 10:59:05 AM
11
Toposurface Help (Merging Surfaces) Road and Curbs |
Tue, Jul 29, 2014 at 8:10:48 AM
Members: | 2080152 | Objects: | 23122 | Forum Posts: | 152264 | Job Listings: | 3 |
