56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Suppress 0 ft??
Tue, Jul 26, 2016 at 2:11:09 PM | Suppress 0 ft??
AndyE13
I have a level that is reading 0" right now because I have suppress 0 ft on.
Is there a way to supress 0 ft everywhere expect in the levels?
Example: all my dimensions that are under 1' have the 0' supressed (how i want it), but my level 1 is reading 0" and i want it to read 0'-0"
There is another forum talking about this but is old so I thought I would start a new one (link to old one below).
http://www.revitcity.com/forums.php?action=viewthread&thread_id=14451
Tue, Jul 26, 2016 at 2:49:42 PM | Suppress 0 ft??
marmiketin1
4.5 Stars: 10 Votes
I assume you have suppresed 0' in the project units? Do not do this. Instead you should supress the 0' in the dimenson type you will avoid this issue of levels showing incorrectly.
Tue, Jul 26, 2016 at 2:54:38 PM | Suppress 0 ft??
AndyE13
That did it! Thank you!
Wed, Jul 27, 2016 at 9:21:05 AM | Suppress 0 ft??
In most cases, it is usually better to set all of your measurement settings independent of your project units.  You should do these in your templates.  As such, you will want to set up several different types in most annotations including all dimention types, levels, spot elevations slope tags, ceiling tags - etc.
In order to model correctly, we usually leave our project units set to the finest accuracy - 1/256" - but we typically don't want a dimension like that.
Suppress Spaces (Geodetic Elevations)
Wed, May 20, 2015 at 10:54:39 AM
Suppress 0s in schedules
Thu, Mar 3, 2011 at 3:31:31 PM
positioning of the dimension text
Thu, Jun 12, 2014 at 11:36:58 AM
Legends Suppress Title on sheet insertion
Sun, Oct 10, 2010 at 2:17:34 PM
Dimension Text Spacing
Thu, Sep 26, 2019 at 7:50:05 AM
Page generation time: 1.6179
