61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Curtain Wall Door Placement Location
Tue, Jul 26, 2016 at 7:22:19 AM | Curtain Wall Door Placement Location
marmiketin1
4.5 Stars: 10 Votes
Having an issue with a curtain wall where the glazing and the door do not sit into the mullion where they should. See attached image showing the problem. The mullion is not a box however it would seem that revit draws an invisible box around the mullions extents and uses that for its left right placement of glazing and doors. I have tried editing the profile for the mullion and making the lines of the stop 'not a reference' but it does not fix the problem. I have also tried using referance planes in the mullion profile as well as the door panel to try and get a parameter to extend the panels further left and right but it does not seem to work. Has anyone encountered this problem and found a solution? Thanks for any help.
Tue, Jul 26, 2016 at 7:43:11 AM | Curtain Wall Door Placement Location
marmiketin1
4.5 Stars: 10 Votes
just figured it out.
Edited on: Tue, Jul 26, 2016 at 7:43:25 AM
Tue, Jul 26, 2016 at 7:46:46 AM | Curtain Wall Door Placement Location
Elnazer2
4 Stars: 5 Votes
i think you can try that trick in that link:
http://curtainwallbim.blogspot.ae/2013/02/custom-profiles.html
it works well with the normal panels i dont know if its gonna work with a door or not but its worth a try .
Editing >>>>> its the same thing you did i was just a few minutes late Winking
Edited on: Tue, Jul 26, 2016 at 7:49:15 AM
Tue, Jul 26, 2016 at 7:52:26 AM | Curtain Wall Door Placement Location
marmiketin1
4.5 Stars: 10 Votes
Thanks yeah it actually explains it in the profile mullion template and I read it but just didnt understand it and then forgot about it. Thanks for the help.
Curtain wall door
Wed, May 12, 2010 at 3:38:11 AM
Curtain Wall Panel to Curtain Wall Door
curtain wall door
Tue, Jan 31, 2006 at 1:36:58 AM
Curtain wall door frame
Mon, Mar 2, 2015 at 11:37:33 AM
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012
Thu, Jul 7, 2011 at 4:27:10 PM
Page generation time: 2.1164
