71 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> Project Address Label
Hopefully this is really simple and I'm just overlooking or overthinking it. I have a text parameter for Project Address in my title block and I'd like to add it to my Title Sheet where I list the legal info of the property. I'm building a template for future projects and I want is to enter the Address in the Project Information on the manage tab and have it appear in the 1st column of the Title Sheet and on the Title Block for all sheets.
This should be done through shared parameters which is not the simplest of things to do and you should consult with your office before changing or adding shared parameters to the Office .txt file which houses this information.
There's no office. Just my laptop.
Heres the help link for shared parameter creation. I would suggest reading through this and the associated sections. This section is the same for almost all recent revit versions.
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-94EA2B8E-2C00-4D29-8D5A-C7C6664DE9CE
I don't want to create a new shared parameter, I want to create an embedded label to toggle visibility, and uses a link to the project info. New post started (my apologies)
Cannot Edit Label After Inserting into Project |
Fri, Sep 14, 2012 at 7:07:14 PM
please help with my title block |
Sun, Aug 29, 2010 at 7:57:05 PM
Project Address Parameters for Title Sheet |
Thu, Mar 23, 2006 at 5:01:01 PM
Address Lable |
Wed, Feb 22, 2006 at 11:30:07 AM
Titleblock Label |
Mon, Nov 21, 2005 at 1:06:02 PM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
