64 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> Create in-fill walls under spiral stairs - Revit Architecture 2013 specific
0 Posts No Rating |
Hi all,
I have a modelling issue in that I do not know how to place a wall under the boundary of spiral (curved) stair. I have two conditions on a project: interior curved stair, and an exterior curved stair.
Could someone be able to provide a step by step instruction on how this is done in Revit Architecture 2013? I cannot use a newer version, so any help in 2013 would be greatly appreciated!
Many thanks,
Austin
see this link:-
http://revit-alize.blogspot.com.au/2006/04/below-stairs.html
an oldie but a goodie.
cheers
0 Posts No Rating |
Hi Mansell5... Many thanks for the link to the fix I needed. It worked just fine in version 2013!
...or, if you need a door in your curved wall, a void swept blend will do the job. Take a look at this link.
Spiral Stairs around a Central Post |
Sat, Apr 16, 2011 at 9:27:29 AM
Revit Arch. 2013 - Material Take-offs on specific areas |
Thu, Mar 7, 2013 at 8:23:26 AM
FYI. Stairs showing through floors in REVIT 2013 [ 1 2 ] |
Wed, Sep 23, 2015 at 2:57:56 AM
19
Spiral Stairs |
Fri, Jul 4, 2008 at 1:34:57 AM
Residential Spiral Stair |
Mon, Feb 16, 2015 at 10:02:06 AM
Members: | 2030512 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
