50 Users Online (49 Members):
Forums >> Revit Building >> Tips & Tricks >> How to locate the objects in distance of "Half Equal, Equal, Equal, Half Equal"?
2 Posts No Rating |
Hi,
Is there any way to locate the objects in the distance of "Half Equal, Equal, Equal, Half Equal"? We used to locate the diffusers in that way.
Thanks!!
Jebakumar
a workaround, but try this........
place seven objects that you want to use, dimension them then hit the EQ option.
THEN DELETE THE 1st, 3rd , 5th and seventh object, adjust dimension lines and hey presto.
the 2nd , 4th and 6th object will be spaced as you require.
Centering Elements WITHOUT using the "Equal" dimension |
Mon, Nov 24, 2008 at 2:38:42 PM
EQUAL CONSTRAINT DIMENSION |
Mon, Jan 10, 2005 at 1:06:29 PM
custom baluster with decorative piece not staying equal 2019 |
Thu, Jun 14, 2018 at 1:54:47 PM
No Equal Toggle for Arc Dimensions?! |
Fri, Nov 6, 2015 at 2:57:13 PM
Dividing a section into equal parts |
Sat, Jul 22, 2006 at 9:45:10 AM
Members: | 2030512 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
