Forums >> Revit Building >> Technical Support >> Curved, slatted facade with holes - any ideas?
Hey there!
I'm trying to make one complicate facade and I need some pro help.
The whole thing is composed from different curved fins. Everything is curved in both vertical and horizontal direction. I've tried to make it from a mass, slatted with many voids, but Revit is going to explode. Finally, I've made a vertical texture in Revit and slatted the whole thing in 3ds Max. Now I have to do the same thing back in the original Revit model. Any ideas what is the best approach? Here is a picture of the idea.
P.S.: The back side of the vertical fins is flat and the front side is curved.
Thanks
Edited on: Thu, Jun 23, 2016 at 6:57:51 AM
see MR. Spot tutorial in the tutorials section titled "Triming walls to the underside of stairs using voids" HTH Post edited on 2006-04-14 13:13:35
This may give you some help figureing it out.
Is your question about how to MODEL this – or, how to graphically REPRESENT it? If the latter, you might explore a material appearance using a cutout. But you’ll need to decide on a single pattern to tile. From the look of it, there doesn’t appear to be one. If you are really thinking of modeling this façade – then I wish you the best of luck. I can anticipate a lot of downstream problems associated with modeling it – including a big hit on performance. Lots of random curves are problematic – especially multi-planar curves.
Random slidding panels on a curved facade ? |
Tue, Mar 1, 2011 at 9:56:45 PM
Complex Facade on a Curved Wall |
Mon, Mar 28, 2011 at 10:00:19 PM
Adaptive rectangular pattern with bubbly holes |
Thu, Sep 12, 2013 at 6:31:28 AM
Double layered honeycomb facade |
Thu, Apr 3, 2014 at 9:29:17 AM
curved/angled walls not joining? |
Tue, Feb 23, 2010 at 7:37:34 PM
Members: | 2098054 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
