24 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Change Change Parameter "Group Under" Category
![5 Stars: 2 Votes](/images/stars_5.gif) |
I’m working with Generic Model families that host several shared, nested components (GM families) each. There got a lot of identical shared parameters in each family and I’m trying to group all these parameters alike – group them under the same heading (e.g. 'Constraints' 'Construction' 'Dimensions') in each family. The problem is that they won’t hold their regrouping. For instance, I change a parameter “group under” category from “Data” to “Dimensions”; save, exit and close, and the next time I open the family, the parameter to back under “Data”. I’ve tried and tried; they won’t hold the changes.
Any help here would be fantastic. Thanking you in advance.
Edited on: Tue, Jun 21, 2016 at 1:36:25 PM
Edited on: Tue, Jun 21, 2016 at 1:37:09 PM
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
Are you just changing the parameter type in the host family? You need to do this in each nested family to have it change correctly.
That’s exactly what I’m doing – changing the parameter grouping in ALL the families nested into the host – as well as within the Host family. I’ve even tried to rebuild one Host from scratch, which seemed to work at first, but then I opened that family yesterday and found its parameters’ grouping wrong again – AND wrong in the nested families. None of the changes are sticking.
"group parameter under" changed upon loading into project |
Wed, Aug 11, 2021 at 3:16:03 PM
"Group parameter under:" |
Wed, Aug 22, 2018 at 10:42:28 AM
11
Possible to change Family category to "Roof" |
Mon, Aug 12, 2013 at 2:32:36 PM
Space "number" parameter to Multi-Category Tag? |
Fri, Dec 13, 2013 at 10:26:02 AM
How do you change a "generic model" family into a "mechanical equipment" family? |
Fri, Apr 6, 2018 at 6:18:19 PM
Members: | 2025968 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
