41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Reclaimed bricks
Mon, Jun 20, 2016 at 8:20:31 AM | Reclaimed bricks
timbuktu2
I am interested to model a project with external walls in reclaimed 'real'  bricks as opposed to generating the geometric squares of standard brick families.
I am aware of detailling techniques for creating this effect for call outs and sections but how does one achieve this effect for the model as a whole?
The wall structure is external reclaimed brick/50mm cavity/internal standard masonry blockwork. TBH I'm not really sure how to create such a family but is this the way to go or am I looking at a rendering option instead?
Any guidance appreciated - thanks.
Mon, Jun 20, 2016 at 2:09:27 PM | Reclaimed bricks
This is a material issue.  You need two things.   An image of that material so you can create a material from that.  To create that material, you also will need to create a bump image from your material image.
This is not a beginner's process - you will have to do some research to learn how to create a material in Revit.
Assuming this is not a coventional brick pattern, you will also have to create a model based pattern to control your material.  If you can determine your brick pattern and spacing, someone here might be able to help you modify a stock, model brick pattern.
Mon, Jun 20, 2016 at 5:07:57 PM | Reclaimed bricks
timbuktu2
Thanks for the advice and I am satisfied that fiddling about with my existing knowledge of Revit would only be a waste of time.
As you correctly surmise the bonding of the brickwork is not standard either (Garden bond) so thanks for indicating how to achieve this too.
I will research your indicators.
Tue, Jun 21, 2016 at 7:31:52 AM | Reclaimed bricks
marmiketin1
4.5 Stars: 10 Votes
I made a quick hatch pattern (no grout) with every 7th row being a common bond course.
Tue, Jun 21, 2016 at 8:06:11 AM | marmiketin1
timbuktu2
Quoting marmiketin1 from 2016-06-21 07:31:52
Thanks for taking the time and trouble Marmilketin and your approach may well provide the simple and speedy solution for the elevations. The common bond every 7th row is spot on for this design too.
Unfortunatly I cant open your hatching pattern because I operate in 2013 but going forward,  I shall look into overlaying a generic wall family with a custom hatch pattern for 2D.
Tue, Jun 21, 2016 at 8:47:59 AM | Reclaimed bricks
marmiketin1
4.5 Stars: 10 Votes
I work in Revit 2013 too and also .pat files are not version specific unless you have a version number stated in the file which I do not. To use the file simply right click on the link and "save as". This will save the file as a .pat file which you can then load into your project as a materials surface pattern.
Tue, Jun 21, 2016 at 9:02:47 AM | marmiketin1
timbuktu2
Quoting marmiketin1 from 2016-06-21 08:47:59
Thanks for that and file now SAVED.
running bricks
Wed, Oct 8, 2008 at 2:51:43 PM
types of bricks
Mon, Sep 19, 2011 at 7:25:32 AM
Bricks are twisted... materials going up instead of sideways
Thu, Jul 21, 2011 at 2:30:06 PM
Rowlock brick Sill
Fri, Mar 16, 2012 at 9:05:18 AM
Quatifying walls
Thu, Sep 4, 2008 at 12:56:55 PM
Page generation time: 0.1850
