53 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> How to set parameter for levels.
![3 Stars: 3 Votes](/images/stars_3.gif) |
For example, if I want the mainfloor is 9', set level 1=0, level two=0+a (a=9'), so for the next project, I only change a=8', all the levels changed automaticaly (more than 30 levels for a typical house)
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
since you cannot have parameters for dimensions in a project on versions earlier than Revit 2016 the best way to do what you need is to use a dimension string at every level and toggle the equal spacing icon which i have circled in the first image. Then you can add a single dimension between level 1 and 2 and then if you select level 2 you can enter the height you want in the dimension. you could also enter the value into the level bubble itself.
That is great. Thanks.
Levels- can they have the same name? |
Thu, Mar 24, 2016 at 12:30:18 AM
Constraining a group parameter to reference levels |
Wed, Jan 10, 2018 at 5:00:30 AM
Assembled Stairs - Joining stringers from one set to the landings of another |
Thu, Mar 13, 2014 at 3:13:48 AM
Levels. |
Thu, Feb 11, 2016 at 8:55:59 AM
Levels |
Fri, Jul 24, 2009 at 3:01:27 PM
Members: | 2017155 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
