98 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> Void Extrusion Constraint
34 Posts No Rating |
Please Please Help !!!
I am attempting to create a twin bowel vanity top starting with the vanity top without a hole that is in the library. In the family editor I cut the holes using a void extrusion. This results in holes and seams ok but when I adjust the height of the vanity top the holes dissapear. The void extrusion obviously has to move up & down with the top to keep it all looking good but I cant work out how to lock the void extrusion to the remaining vanity top.
Any clues greatly appreciated.
Also would like to know if there are other reference options available to solve these type of problems. I waste hours on this type of problem.
Regards Steve
select the void and use its grips to drag them to the face of the element they are cutting then lock them. Alternatively and preferably place constrained reference planes at the appropriate height and lock the void to them using the same method.
HTH.
I was having a similar problem, refer this thread
http://www.revitcity.com/forums.php?action=viewthread&thread_id=3638
void extrusion not cutting solid extrusion |
Fri, Oct 10, 2008 at 3:47:43 PM
Make void extrusion permanent |
Wed, Feb 9, 2022 at 6:46:57 PM
top/base constraint as a parameter in family types |
Wed, Sep 9, 2009 at 4:49:38 PM
Void Extrusion in window family problem |
Mon, May 18, 2015 at 3:55:23 PM
Void Extrusion |
Tue, May 28, 2013 at 8:15:38 PM
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
