53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Visibility Dialog Slow to Appear
Wed, Jun 1, 2016 at 8:11:54 AM | Visibility Dialog Slow to Appear
nednarb80
We have a 230mb 2015 Revit model which suddenly and for all users, takes about 4 minutes to open VG. We've tried saving a new central, compacting, auditing, purging, and unlinking all files to no avail. We do still have 150 warnings which need to be cleaned up. Our other thought is to delete families in chunks to see if one of them could be the culprit. Does anyone have any experience with this? Any suggestions we might try?
Thanks,
Branden
Wed, Jun 1, 2016 at 8:28:14 AM | Visibility Dialog Slow to Appear
Since this was 'suddenly', it suggests it is something added to the file.  Are you on subscription?   If so, then send to Autodesk and you should see something today.
If not, how well is your file broken up with worksets?  We place each linked file in a workset, the shell in a workset and interiors in a workset.  That allows us to unload not needed worksets for better operations.  If you have done similar, unloaded worksets may help you pinpoint your problem.
If you have older backups, you might open those detached to see if you can get a handle on when something was introduced in the file.   You could also copy central and backup folder to a new folder where you can do rollbacks without affecting your current file.
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:22 AM
WHY THE A.REVIT BUILDING GOES SOOO SLOW?
Fri, May 4, 2007 at 2:43:19 AM
REVIT RENDER QUALITY SETTINGS DIALOG BOX
Thu, Dec 18, 2008 at 11:04:04 AM
Revit Dialog Box When Opening
Thu, Feb 25, 2016 at 9:32:50 PM
revit running slow
Mon, Feb 15, 2010 at 2:40:52 AM
Page generation time: 0.8109
