47 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> Window not in correct location in a stud wall
0 Posts No Rating |
Just learning Revit and I have a problem placing a window in a wood stud wall, 1/2 osb sheathing and stucco finish exterior 5/8" gyp interior. The 'J' flange keeps locating itself on the face of the stucco and not the sheating. So the exterior face of the window is projecting outside the face of the stucco. Can't get it to relocate. I can use 'setback' in the properties window but it only will more further outside. A negative setback value gives me an error. Any thoughts. thanks!
Either the family was built wrong or you have the family reversed - inside/outside.
Window in brick/stud wall |
Fri, May 26, 2006 at 2:43:48 AM
Window Placement in Stud/Brick Veneer Wall [ 1 2 ] |
Wed, Feb 4, 2009 at 11:22:19 AM
15
RAC 2012: Window Trim Reveal in brick/Stud Wall |
Mon, Jul 2, 2012 at 2:08:10 PM
Wall type within a window family |
Wed, Sep 19, 2007 at 4:05:56 PM
Stud wall family help PLEASE.... |
Fri, May 9, 2008 at 1:09:58 PM
Members: | 2022271 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
