66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Issue with annotation nested with generic model family
I have a family that is wall based with a generic annotation nested in with it to display a symbol in plan in the project. The problem I'm having is that when the model sits above the cut plane, the annotation that's loaded into the family also disappears. If the model is being cut by or sits below the cut plane, everything works fine. My question is basically if there is a way to have the annotation show up even if the model that the annotation is loaded into is sitting above the cut plane. I've attached an example of the family in question so you can see what I'm working with. I appreciate any help that is provided.
If the family is non-cuttable, you can place a vertical invisible line in the family that will intersect your view cut plane, then the entire family will show.
Is the only way to make a family not cuttable is to change its category? Thanks for the response
Yes ... but we are talking about your wall based family, not the nested family. Is that also generic?
It is generic but can be changed if necessary to get the family to function the way I want.
Got it to work, Thanks for you help!
Text issues with generic annotation family nested into detail component. |
Mon, May 19, 2014 at 11:27:43 AM
Annotations nested inside a wall hosted equip family: Cant see the annotation |
Wed, Aug 20, 2008 at 6:37:31 PM
Nested Annotation Family in a Detail Component |
Fri, Mar 16, 2012 at 8:56:45 AM
Generic Annotation with Family Category based parameter |
Mon, Sep 16, 2013 at 7:18:15 PM
Draggable Line in an Annotation family? |
Thu, Jul 5, 2012 at 1:30:26 PM
Members: | 2016968 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
