28 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> Converting Model Views to Drafting Views
Fri, May 13, 2016 at 10:51:03 AM | Converting Model Views to Drafting Views
CDWdavid
5 Stars: 5 Votes
Does any easier way to convert a model view to a drafting view?
I'd like to create all "standard details" in drafting views, if the Autodesk can develop a way to convert the model view to a 2D drafting view, just as it does for creating DWG files, it would be much easier to Revitalize our detail library.
Fri, May 13, 2016 at 11:38:39 AM | Converting Model Views to Drafting Views
Johnzo142
Have you tried the 'Freeze Drawing' tool?
Fri, May 13, 2016 at 12:31:57 PM | Converting Model Views to Drafting Views
Essentially the freeze drawing app simply exports to CAD which you can do manually.   The problem is that it is a CAD file.   If you explode that in your project, you get all the CAD crap.  If you want to create standard Revit detail, clean up these files in a program by revitizing them, then save the detail.
Fri, May 13, 2016 at 12:43:16 PM | Converting Model Views to Drafting Views
CDWdavid
5 Stars: 5 Votes
Thanks for both.
That is what I am looking for, to avoid the CAD craps.
Also, I will be able to create some isometrics from 3D views with proper Revit materials Cryingnot CAD 3D) into our detail library, which is the strength of the Revit.
Edited on: Sat, May 14, 2016 at 1:34:49 PM
Fri, May 13, 2016 at 1:21:02 PM | Converting Model Views to Drafting Views
If you want 3D views with materials, then it must be model views - not detail.  If these will be something you place in models, use a group.   Those can be stored in your library and brought into any model.
Fri, May 13, 2016 at 2:13:29 PM | Converting Model Views to Drafting Views
CDWdavid
5 Stars: 5 Votes
That's why I posted this thread in the WISHLIST.
I wish all those can be in drafting views for easier to copy and paste onto sheets.
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
Save a sheet of drafting views
Wed, Mar 1, 2017 at 5:34:28 PM
copy drafting views from linked model
Tue, Feb 15, 2011 at 9:44:11 AM
converting drafting views to previous version revit
Tue, Dec 8, 2015 at 7:38:34 AM
DRAFTING VIEWS ON MORE THAN ONE SHEET (REVIT 2012)
Wed, May 23, 2012 at 8:42:46 AM
Page generation time: 1.0340
