35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> File path
Wed, May 11, 2016 at 6:48:21 AM | File path
arsodi
I am having problem with my file path. i attached the file how it says on screen. how can change it and where should be template files.
Wed, May 11, 2016 at 7:41:31 AM | File path
The template files are in the library where you saved them during the install.
The message you see on the screen refers to the Revit options that you find by clicking on the R in the upper left corner.  Pick options, then you can set the correct paths to your files.
BTW - This and many other useful answers can be found in your HELP.   Learn to use it !
Central File Path on a local file
Sat, Oct 24, 2015 at 10:21:21 AM
File Path stamp
Sun, Apr 23, 2017 at 1:03:48 AM
File Path in Titleblock
Wed, Nov 10, 2010 at 10:48:56 AM
can't view file properties - central path
Fri, Aug 21, 2009 at 2:34:54 PM
Plot stamp: Set file-path to Central
Tue, Jun 7, 2016 at 8:33:01 AM
Page generation time: 0.8136
