25 Users Online (24 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Advice on Curtain Systems and Slabs from Mass
Mon, May 9, 2016 at 7:40:52 PM | Advice on Curtain Systems and Slabs from Mass
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Does anyone have advice for using a mass to create both curtain system and floors? I'm running into a Revit limitation where I've built my mass to represent the edges of slab. I then create curtain system comonents that have the desired offset from the edge of slab since I don't want Revit to create overlapping elements. However, this approach destroys any possibility of joining the corners of the curtain system correctly since the edge of the curtain system do not extent to join to themselves. Weak Revit. I'm not seeing any way to overcome this without having to create a seperate mass. I had hoped that I could use the same face representing the slab edge boundary to be used as the curtain wall. Let me know if you have a good process for this because it would be awesome if revit could do this. Cheers.
Tue, May 10, 2016 at 7:12:42 AM | Advice on Curtain Systems and Slabs from Mass
Why are you using a mass?  Please explain with some images.
Tue, May 10, 2016 at 12:04:21 PM | Advice on Curtain Systems and Slabs from Mass
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Why not? Short answer; I want to explore using the mass as the basis for constructing the building elements and have global parametric control over the form. Additionally, I want to investigate the process in a way that could inform more computationally based form generation done using dynamo, etc. I'm hoping to uncover a fully BIM design and delivery process. Here are some images:
Tue, May 10, 2016 at 12:08:18 PM | Advice on Curtain Systems and Slabs from Mass
Mass based elements vs normal has always been problematic in the past.  They may have changed (maybe improved) some of these functions but in the past, you had to edit the mass to edit your element.  It appears that you still have the same problem.
You don't have to use a mass to successfully use dynamo.
Tue, May 10, 2016 at 12:17:57 PM | Advice on Curtain Systems and Slabs from Mass
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Yeah that's the issue. I understand the fact that you don't necessarily need an understanding of the mass to use dynamo, but boy how helpful it is! Generating form geometry and hosting building elements is critical for complex application. Especially in the case of generating curtain walls that you don't always want to be made up of adaptive components. Looks like Revit has left me a little high and dry here, so I'll have to abandon this effort for now. Thanks for your feedback!
Curtain System from Mass - Mullion Joins
Fri, Dec 11, 2015 at 7:27:44 PM
Conceptual Mass and Objects by Face Workflow Problem
Wed, Sep 5, 2012 at 7:19:24 PM
Can't hide Curtain Grids
Fri, Apr 20, 2012 at 5:58:53 PM
Double-Skin Facade as a "Curtain System" on a "Mass".
Sat, Nov 21, 2015 at 7:10:28 AM
Curtain system from mass - Revit 2014
Fri, Jun 17, 2016 at 12:20:49 PM
Page generation time: 2.8464
