101 Users Online (100 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Revit 2012 template family files (.rft)
Mon, May 9, 2016 at 1:40:57 AM | Revit 2012 template family files (.rft)
Roland1968
hi everyone
anyone got the .rft files for revit 2012 (or earlier) to share? i need these to create custom .rft files, the later versions don't let you change the file extensions anymore so i want to try to change these to .rfa files, open them on rvt 2016 and then modify these and save as .rfa. i should be able to change these back to .rft in the 2016 version afterwards.
just a bit fed up with some of the stock templates not doing what i want, especially the window and door template. i'm trying to swap the origin from sill to head (soffit) height but because i can't modufy the 2016 template the constraints text stays at Sill Height even thou it refers to the head hight.
i'd appreciate if annyone can help me with these files, unfortunately i have deleted my old template folder
Tue, May 10, 2016 at 7:12:24 AM | Revit 2012 template family files (.rft)
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
If you use the following search string in google it will search for rft files."index of" + "rft" + "template" -html -htm -php
Family Template Files (*.rft) & RISAFoot Files (*.rft)
Fri, Feb 2, 2007 at 12:41:03 PM
Revit 2015 Missing Family Template Files
Thu, Nov 13, 2014 at 6:45:25 PM
lost .rft files
Mon, Jun 28, 2010 at 7:02:40 PM
Family Template files
Thu, Apr 5, 2007 at 9:01:56 AM
Conceptual Mass: Revit Architecture 2012 (Trial V.)
Mon, Jun 30, 2014 at 7:20:05 AM
Page generation time: 2.9356
