85 Users Online (84 Members):
Forums >> Revit Building >> Technical Support >> modelling
6 Posts No Rating |
Hi fellow revit users
wondering if you can help I am setting up a camera in my project to view various angles of a rock wall. In 3D the rock wall looks fine in a camera view the same wall is almost black I have tried using both drafting and modeling patterns for the surface of the wall but no luck.'
any help appreciated.
thanks
luapj
![pepsiqueen Avatar](user_avatar/5618.jpg)
136 Posts No Rating |
what if you render the 3d view with a rock material instead of just a shaded view
6 Posts No Rating |
Hi thanks for the response,
I dont have the time for the rendering this is for a quick presentation but would still like to have the rock wall visible in the shaded view as it is in the 3D view
we work in metric in australia and I was thinking because the fill patern was created in imperial units that i would somehow have to cahnge the scale when impoting the pattern in, however it will not allow me to change the importing scale either.
cheers
luap
1 Posts No Rating |
Hi,
I have had rock walls go black in shaded mode when they are CURVED in plan. I had a great looking rock pattern working on the other sections, but the one section that was a curved line showed the pattern as solid black. Seems like a bug...
Sorry for the bad news. Get to like black.
best regards,
Chris
6 Posts No Rating |
thanks chris
this is not a curved wall and it only appears black when i have set up a camera view
cheers
![3.5 Stars: 2 Votes](/images/stars_3.5.gif) |
Have you tried changing the color for the rock material in the material library? It defaults into an average color of the image which is to be used for rendering.
I would also try chanigng the color of the surface pattern in the object styles window or object properties.
The other option would be to change the scale of the camera so that image is larger and the scale of the pattern is reduced, then shrink to fit when printing.
Those are just a few quick ideas hopefully one will work or spur some other ideas.
6 Posts No Rating |
thanks
will give them a go
luap
HELP! WHERE IS THE MODELLING TAB LIKE IN RAC2010? |
Fri, Oct 23, 2009 at 10:38:24 PM
Modelling Lake&Stream in Revit 2009 |
Wed, Jul 29, 2009 at 9:04:17 AM
a better 3D modelling environment |
Mon, Aug 6, 2012 at 1:10:07 AM
input devices for modelling |
Wed, Oct 26, 2005 at 9:26:45 PM
modelling interior nightclub |
Tue, Sep 6, 2005 at 3:57:38 PM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
