77 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Window family
Mon, Apr 10, 2006 at 1:43:37 AM | Window family
cadjockey
Hi all, I am creating timber louvred window screen family. I have set a height parameter to manipulate the head height as required. As the height changes the number of timber louvre slats will need to increase or decrease in order to retain the same distance between themselves. Is there a function/parameter I can use that will allow this to happen? cadjockey
Mon, Apr 10, 2006 at 8:29:00 AM | RE: Window family
bolandereric
If you use an Array you can put a Parameter to it, then go in to the family type and add a formula that will add them as the window gets bigger.
Tue, Apr 11, 2006 at 7:56:09 PM | RE: Window family
Ultramarine
There is a good tutorial on the topic of "Arrayed & Nested families" by Mr Spot, which covers just this sort of family - I can recommend it! Ultramarine
window frame family + nested window frame fill
Wed, Apr 12, 2006 at 7:31:30 AM
Imported family not flexing in window family
Thu, Jan 31, 2013 at 7:21:53 AM
Window Legends-showing nested components
Thu, Mar 20, 2008 at 4:20:36 PM
having trouble with window rfa
Mon, Sep 8, 2008 at 10:37:11 AM
basic window family tutorial(step by step)
Mon, Sep 6, 2010 at 7:26:53 PM
Page generation time: 1.3491
