104 Users Online (103 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2014 - An error has occurred while drawing the contents of this window
Tue, Apr 26, 2016 at 10:09:27 AM | Revit 2014 - An error has occurred while drawing the contents of this window
Jakesie
Good day, I need some advice.
I work with Revit 2014 for a few years on teh same laptop, whithout any issues. This week I've installed Adobe After Effects, and since then, everytime I run After Effects, mty revit respond whith the error  {An error has occurred while drawing the contents of this window}
Now, it can be resolved by unticking the Direct3D option, but that make my revit slow, and graphics poor. Rhe error resolve whith a restart, until I run After effects again.
Any help or idea how to treat this perhaps? I have updated my graphic card drivers with no joy Sad
Kind Regards,
Johan
Tue, Apr 26, 2016 at 2:29:14 PM | Revit 2014 - An error has occurred while drawing the contents of this window
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
things to try....
Check to see you GPU is on the Gestapo's approved list.
Turn Hardware Acceleration to whatever it is not now.
If it happens while one 3D view window is active, delete the window.
Audit & Detach, Purge, remove all extraneous stuff like linked DWGs, redundant images etc.
Change Windows Display setting to whatever is not now. eg. smaller text, apps etc
Dumb down windows settings to increase performance.
Clean out temp folder and local folder.
Apply all the Revit 2014 updates.
Upgrade to Revit 2015 or even 2016.
Free up RAM where you can. Add RAM.
Only use one software at a time.
Get a faster computer.
Wed, Apr 27, 2016 at 10:27:57 AM | Revit 2014 - An error has occurred while drawing the contents of this window
Jakesie
I like your logic - get a faster computer  Smile
Thanks for the reply. Well, I have a Core I5 whith 8 Gig RAM and 2 Gig Geforce dedicated card. I doubt the pc is too slow. Besides, Revit work well all the time, whithout any issues, ecxept when I start After Effects. It seems like Direct3D is being affected by After Effects. ( I have tried to run After effects whith the on on board graphics card, while Revit run with the Geforce, and so far no problems....)
Display error: An error has occurred while drawing the contents of this window.
Wed, Aug 24, 2011 at 6:21:14 PM
3D window error message-Revit 2009
Fri, Sep 15, 2017 at 2:51:33 AM
"error while drawing contents of this window" error. What is causing it?
Mon, Aug 25, 2008 at 5:58:47 PM
12
Print Error "Display Error"
Tue, Dec 20, 2005 at 5:04:34 PM
MEP 2012 - Error that causes windows to close.
Tue, Nov 6, 2012 at 1:06:00 PM
Page generation time: 5.9297
