82 Users Online (81 Members):
Forums >> Revit Structure >> Technical Support >> Disassociating work plane
I'm really struggling with a work plane issue.
I'm creating metal trusses from scratch using plate extrusions. When creating the extrusion, I used workplanes to locate the piece (either grid line or named refrence plane) and then disassociated the piece. However, when I try to move it, it will only go in one direction like it does when it is associate to a work plane. When I check, there is no association.
When I go all the way into the extrusion I can move those lines where I need to but that will be a complete pain in the neck to do for each piece in the truss. Any thoughts?
Are you talking about in the family, in the project or in an in-place family? Have you tried checking the disjoin box on the options line? NOTE: This will delete any associated dimensions or tags.
Each element of the truss is an in placed modeled extrusion. Does that help you?
Did you try what I suggested?
In-place models should really be used for one of a kind elements.
BTW - Revit is always associating objects, sketch lines, annotative lines with other elements in you projects.
As it turns out, I had the "constrain" copy checked. I was thinking I wanted to make sure they were all in a nice straight line but it only wanted to constrain along the original associated path.
Set roof or soffit on work plane? |
Mon, Dec 2, 2013 at 12:57:49 PM
14
Work Plane Error |
Thu, Nov 5, 2009 at 8:41:13 AM
get rid of current work plane and 3D snapping |
Fri, Nov 10, 2006 at 3:26:52 AM
Orient a view perpendicular to a work plane |
Thu, Dec 17, 2009 at 11:52:39 PM
Floor & Work Plane Error Message |
Thu, May 4, 2017 at 8:01:02 PM
Members: | 2017008 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
