39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2016/2015
Tue, Apr 19, 2016 at 10:17:31 AM | Revit 2016/2015
HermanMunster
This is more of a design/phasing/graphics question. On the plan attached I want to grpahically demonstrate any interior element design changes to the client on the floorplan. How do I want to do this? By having the element (desk/toilet what have you) highlight in a different solid color when moved.
I have edited the family by adding an additional color parameter which manually has to be selected for each family that has location revised on plan. i.e fridge has chrome additoinal color is red.
Does this make sense to revise the family by adding a material instance parameter with a yes/no parameter so when the family is loaded into the plan the user has the ability to click yes or no to edit the graphics?
waiting for wwhub to shred the vernacular within this post in 3....2....
Tue, Apr 19, 2016 at 10:46:27 AM | Revit 2016/2015 Add Yes/No Parameter to Family Material
HermanMunster
I have created two materials parameters and two yes/no parameters. Do I write the formula in the material or yes/no parameter so I can link one to another.
I would like to have the family loaded in the model and once selected have the ability to select Client or Arch in the properties and have the graphic display change
Tue, Apr 19, 2016 at 11:06:40 AM | Revit 2016/2015
3.5 Stars: 395 Votes
You do know that you can set over-rides for but cut and projection lines per phase?
Wed, Apr 20, 2016 at 10:21:57 AM | Revit 2016/2015
HermanMunster
Cheers WWhub.  I found this and it worked beautifully in the famliy and then in plan. Thought I would share.
Re: IF/THEN Formula and "Yes/No" ParameterI have three solids that look like a 1, a 2, and a 3, the visibility for each is defined by params V1, V2, and V3. V2=V1 V3=not(V1) Thus, if 1 is visible, 2 is also visible, but 3 is not. If 1 is NOT visible, 2 is also not visible, but 3 is visible.
Revit 2016
Thu, Mar 31, 2016 at 11:00:08 AM
12
REVIT 2015 DELETE FAMILIES FROM FILE BEFORE OPENING IT - UNRECOVERABLE ERROR
Thu, May 12, 2016 at 7:57:15 AM
Details from 2015 messed up when loaded in 2016
Fri, Nov 20, 2015 at 3:15:52 PM
Massing appears when exporting from revit 2016 to navisworks 2016
Tue, Feb 2, 2016 at 11:28:30 AM
Twinmotion 2016 and Revit plugin 2014-2016
Tue, Nov 24, 2015 at 9:42:01 AM
Page generation time: 1.9173
