Forums >> Revit Building >> Technical Support >> wall wrapping at curtain wall "inserts"
14 Posts No Rating |
Anyone know how to make a wall layer wrap at a curtain wall "insert"? We have large glass wall openings in our solid wall that I made by cutting geometry, but the solid wall's layers don't wrap as they do at a normal hosted window.
have you tried setting wall ends to wrap ?
yes, but that doesn't affect these. Revit apparently doesn't regonize curtain walls as inserts.
aren't there more people with this problem, or is the solusion that simple...please reply.. can't find more threads on the subject.
Hi "mhildebrandt", do you create your wall by a normal "system wall family" or "create in place" a mass like a wall then "Cut" the mass where the curtain is placed?
I do by the two systems i told before and it's work...
wall layers not wrapping at curtain wall inserts! |
Fri, Mar 4, 2016 at 10:27:08 PM
Wall Wrapping at Inserted Wall |
Thu, Aug 27, 2009 at 8:44:18 AM
WALL WRAPPING AT INSERTS PROBLEM |
Thu, Jan 29, 2015 at 6:56:17 AM
wrapping of wall inserts |
Fri, Jul 14, 2006 at 5:13:18 PM
wall wrapping problems |
Wed, Mar 4, 2015 at 9:59:02 AM
Members: | 2097997 | Objects: | 23164 | Forum Posts: | 152289 | Job Listings: | 3 |
