62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Overriding Parts in View
Hello again,
please tell if there is a way to override in view wall parts, - say, one part is existing (gray), another two - new (white with materiall patterns).
I just can't override them.
Please help. (Revit 2013)
The only way to do this is to use the Create Parts tool on the Modify tab and do the individually. Be careful though because once you use this tool you can't make it all one wall again. In 2013 I'm not sure if this command exists and if it doesn't you would have to draw them as seperate walls.
Thank you. I switched to Revit 2014, i will try this.
Best regards,
G.
I figfured it out. It is in the view properties, section "Show Parts".
What about making separate walls, it will be long if you have windows there. In addition,you will have thick cut lines of walls inside of your structure, and you would override the lines. Do i understand it correctly?
Thenk you for your help.
Best regards.
Parts / Structural Deck Visibility |
Mon, Jun 15, 2015 at 5:00:30 AM
Overriding grids of a linked model in view |
Wed, Oct 30, 2019 at 10:46:45 AM
overriding materials for linked model revit |
Wed, Jun 22, 2016 at 7:29:03 PM
Parts v cut profile |
Wed, Feb 8, 2017 at 11:01:08 AM
Parts |
Fri, Sep 16, 2011 at 2:25:10 PM
Members: | 2030502 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
