31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Levels Reference Height
Fri, Apr 15, 2016 at 10:26:19 AM | Levels Reference Height
SteveB
3.5 Stars: 5 Votes
Is there a way to change the elevation info the Levels displays?   By default, levels display the height above the project basepoint.   In the same way that you can display elevations in "relative base" above a certain level.  No one cares how high a ceiling is above sea level or the Revit project base point.
Fri, Apr 15, 2016 at 11:32:53 AM | Levels Reference Height
3.5 Stars: 395 Votes
The answer is in your HELP.  You can move your project base point to wherever you want and you can modify your levels to reference project base point or survey.
Ceiling tags can be made to reference height above their floor level.
It's all in your HELP.
Constraining a group parameter to reference levels
Wed, Jan 10, 2018 at 5:00:30 AM
reference plane depth/height
Wed, Jul 7, 2010 at 3:11:31 PM
Best Approach to Levels? Construction or finish
Mon, Sep 22, 2014 at 10:43:18 AM
Schedules & Levels
Fri, Feb 24, 2006 at 2:08:54 PM
type mark tags and height/width reference
Mon, Apr 13, 2015 at 10:04:42 AM
Page generation time: 0.4708
